Model A1224 / Early 2009 / 2.66 GHz Core 2 Duo processor
102 Questions View all
Actualizacion del sistema para que sea mas rapida
Tengo una iMac 20” Early 2009 con OS-X Yosemite 10.10.5 con un procesador 2.66 GHz Intel Core 2 Duo y 2 GB en memoria RAM.
Como la puedo actualizar para que sea mas rapida?
Y su costo?
English: System update to be faster
I have an iMac 20” Early 2009 with OS-X Yosemite 10.10.5 with a 2.66 GHz Intel Core 2 Duo processor and 2 GB of RAM memory.
How can I update it to be faster?
And its cost?
Add a comment
1 Answer
Hay dos cosas que puede hacer para actualizar su hardware, aumentar la RAM a 8 GB e instalar un SSD. También me gustaría actualizar el sistema operativo a OS-X Yosemite 10.11.6
Pero antes de hacer todo esto, tenga en cuenta los costos, y Yosemite ya no recibirá actualizaciones de seguridad.
How to get old versions of macOS
English: There are two things you can do upgrade your hardware boost the RAM to 8 GB and install a SSD. I would also look at upgrading the OS to OS-X Yosemite 10.11.6
But before you do all of this keep in mind the costs, and Yosemite is no longer getting security updates.
iMac Intel 20" EMC 2266 RAM Image
Guide
iMac Intel 20" EMC 2266 RAM Replacement
Difficulty:
Easy
1 - 10 minutes
iMac Intel 20" EMC 2266 Hard Drive Image
Guide
iMac Intel 20" EMC 2266 Hard Drive Replacement
Difficulty:
Moderate
45 minutes
Add a comment
Add your answer
luis_r_0908 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 77
