A2115 / 2019 / Processors from 3.0 GHz 6-core i5, up to 3.6 GHz 8-core i9. Released March 19, 2019.
136 Questions View all
Can I change the logic board to iMac 2019 A2115 in my iMac 2012 A1419?
Because i saw the pdf and i want to upgrade my imac, my imac is the imac 27 inch A1419 2012 late and I want to replace the logic board into a imac 2019, It is possible? Thank you very much :D
Score 1
Add a comment
1 Answer
Most Helpful Answer
Sorry no ;-{
Apple did use the same case and power supply but the display is very different! Yours won’t work.
Score 1
2 Comments:
So dose that mean it‘s possible to replace the logic board while replacing the screen also?Cuz I got i 2013 A1419 imac with a broken screen and I wanna have an upgrade while replacing the screen.
If anyone know pls tell me thx!
by
@tinsley - So if I fully gut you out and transfer someone else into you, are you then them?
Sorry it’s not that simple and clearly neither of you would live in this bad example.
The point is simply NO there is too much different in the fittings.
by
Add a comment
Add your answer
Y FS will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 13
All Time: 224
