Third generation of the Fitbit Charge fitness tracker series.
22 Questions View all
Fitbit Charge 3 charging pinout?
I was looking for the pinout earlier and nobody on the internet had the answer...
I ended up buying a charger clip and promised myself to post the pinout to help anyone who needs to charge it without the clip.
Score 5
Add a comment
1 Answer
Most Helpful Answer
From left to right:
  • +5V
  • not in use
  • GND
Score 8
3 Comments:
Appears that this info is also correct for the Fitbit Charge 4 as well.
by
I brought Fitbit charge 3 band for less than $1 at scrap store. Thank you for the information, i needed it finally, now I will hack into it
And add new battery and charge without the clip...
by
Also worked on a Fitbit Inspire 2, which looks similar on the underside. 5V (red) on the left contact, GND (black) on the right, when oriented like the photo.
by
Add a comment
Add your answer
io nut will be eternally grateful.
Past 24 Hours: 5
Past 7 Days: 19
Past 30 Days: 72
All Time: 3,110
