Televisions made by the Chinese multinational electronics company, TCL.
TCL 55R615 Screen Flickers Red
I have a TCL 55R615-CA, and after setting it up on a wall mount I noticed the screen seemed to have a flicker, particularly when displaying significant areas of white. I took a slow-mo video of the screen with my iPhone to see if I could tell what was going on. It appears that the screen flickers between full color and monotone-red (which is why it wasn’t immediately apparent on the Roku menu screens).
I’ve tried doing a display setting reset, a factory reset, unplug/re-plug, and adjusting each of the display setting when on a specific input with no appreciable change in the flickering. Is there something I can do to fix this?
Add a comment
Chosen Solution
Yes, I took it down off the mount to see if that did it and it didn’t help.
I did fix it though. I took the back off, exposing the circuit boards and found a loose connector between the mainboard and the T-con board. A little press with a click from the connecter, and much to my releif the TV turned on with no problem.
I guess the connector was never properly installed, and my jostling the TV must have caused a couple of the contacts to finally break their connection.
Add a comment
Most Helpful Answer
Hi @fearra ,
Does it still do this if you remove it from the wall mount and try it on a stand (or carefully just holding it)?
Have read with other models that sometimes when wall mounting, pressure is placed on the mainboard by the mount being screwed too tight etc
Score 1
Add a comment
Add your answer
Jon S will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 7
Past 30 Days: 34
All Time: 1,629
