Repairs for most tablet computers. Because of their small size and frequent use of adhesive, tablet repair is often more involved than laptop repair.
non responsive when connected to microscope
Tablet SX-PD975A came with a digital microscope. It is non-responsive to touch when plugged into microscope but not when attached to laptop. Touching specific icon should activate but nothing happens.
Add a comment
1 Answer
Most Helpful Answer
Hi
What is the make and model number of the tablet?
Most likely the microscope needs to be connected to the tablet via a suitable OTG cable (On The Go) so that the microscope can receive power from the tablet, to operate. The OTG cable needs to have the correct USB plug at one end that matches the tablet’s USB port e.g. micro USB or standard USB type
USB power is normally provided all the time from USB ports in a laptop or desktop computer but not from a tablet (at least not an Android OS tablet).
The OTG cable is wired so that when it is plugged into the tablet the tablet will provide power on the USB port for the device connect to the tablet so that it can operate if it hasn’t got its own power supply e.g. USB flashdrives, microscopes?
Here’s an image that shows the wiring difference between a standard USB cable and an OTG USB cable. You can see the wiring change that is used to signal the OS in the tablet
(click on image to enlarge for better viewing)
Be aware that connecting a device via an OTG cable to a tablet will mean that the tablet’s battery will be discharged faster as it is also supplying power to the device as well as the tablet.
Score 1
Add a comment
Add your answer
mtomka will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 74
