Repair guides and disassembly information for Google's Pixel 4 XL smartphone, released in October of 2019.
57 Questions View all
Front camera and Face ID stopped working after disassembly
Hi friends,
I teardown my pixel 4XL to replace rear camera. But when I assembled again, my front camera and faceid can not work. Face enrollmend didnt work , front camera black screen when flipping from.rear camera to front camera. I am quite sure I teardown carefully.
Really appreciated your help.
Thanks
Score 1
Add a comment
Most Helpful Answer
I too am having the same problem I even replaced the front camera and sensor assembly. The camera app doesn't work for front camera at all. It dose however show a B&W imagine on other apps but it isn't using the camera but the sensor to the left of it.
Score 1
1 Comment:
were you able to find a solution to this? i am having the same problem. already replaced it and yet nothing on camera app. i also have the BW on other apps.
by
Add a comment
Well possible reason maybe that the clip connector is not properly connect to the main board, which will cause the face id not to function as well and also result to the black screen when camera flips from rear to front.
Or the flex connector connected to the main board is cut now.
Add a comment
Add your answer
Tan Vo Huu will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 606
