Guides for the Wi-Fi version of the iPad Mini 4—model A1538. Announced on September 9, 2015, the iPad Mini 4 is the successor to the iPad Mini 3.
90 Questions View all
Lines in screen and non functioning home button after battery replace
After replacing the battery on my iPad mini 4, everything went to plan, but now there are lines across the screen and the home button lost most functionality. Touch ID still works, but I had to add an accessibility button to the Home Screen in the interim. There is NO visible damage to anything, all connections are seated. Any ideas?
Add a comment
1 Answer
If you confirmed the connections are seated and there is no physical damage that you can spot, odds are you most likely damaged the LCD. As far as the home button goes, that could be damaged as well. Typically I see that specific issue after the screen has been replaced and is usually caused either when the bracket for the home button doesn’t quite line up right or the little button that clicks when you press it becomes damaged. That can be repaired by a skilled micro soldering tech but if you just want to restore the function to return home and multitask, just order a replacement button along with a new screen. Just be aware that by replacing the button, you will permanently lose touch ID unless you use the original one. The original home buttons with TouchID are paired to each board. The only way to maintain it is to use a special tool that only apple has.
Add a comment
Add your answer
Kevin Monaghan will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 1
All Time: 301
