"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
56 Questions View all
Broken Hinge, and WLAN connector.
The hinge for my monitor broke a screw connection to my wrist plate, and has now basically broken off from the PCB itself. In the process of opening the bottom plate, the WLAN cables came off. I already disconnected the battery and took out the WLAN module just in case anything happens.
Is there a way to fix the hinge or at least put it together to be useable again?
1 Comment
To clarify, pulling out the backplate pulled the WLAN cable's crimps out. So, i think i might need to recrimp the cables and reconnect to the wlan module
by
Add a comment
1 Answer
Most Helpful Answer
Hi @joship ,
You will have to replace the WLAN antenna cables.
They are a co-axial type cable i.e. inner conductor separated by insulation from an outer shield wire so crimping a new connector on will not work unless you know how to crimp coax connectors that is. Checkout the antenna cable sockets on the WLAN card to see the inner and the surrounding outer connector of the socket.
Search online for Dell XPS 9550 WiFi antenna cables to find suppliers.
Here’s the service manual for the laptop, taken from this webpage which will help, as it details the necessary pre-requiste steps and then the procedure to completely dis-assemble the laptop.
With the hinges unless you’re prepared to use a nut and bolt arrangement through the palmrest assembly to overcome the broken hinge mounts you will have to replace the palmrest assembly.
Other people have had the same problem with the hinges on this model. Here’s a link that may help - see the images in the 2nd answer Display hinge broke from base
Score 1
Add a comment
Add your answer
JoshIp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 8
All Time: 318
