Samsung's flagship phone-with-stylus and the successor to the Note8, released August 2018. Features a 6.4" display and up to 512 GB of onboard storage.
104 Questions View all
Phone echos very badly after repair
I can’t remember if this started before or after the screen repair I performed, but it was around that time. If I’m on speakerphone or a video chat, the other parties can hear a bad echo. Sometimes it just sounds “laggy”. Some of the troubleshooting steps I have taken include:
Factory reset
Replace charge port (has a microphone on it)
Replace loudspeaker
I have no idea what else to try. I repair phones daily and have never encountered something like this. Any and all solutions welcome. Thank you!
Add a comment
1 Answer
Most Helpful Answer
Hi @e_ahh ,
Don’t know the answer but have read that the Galaxy Note 9 has 8 wide field microphones, so maybe you need to recheck all the connections that were disconnected due to the screen repair.
Presumably the mics are used when in loudspeaker mode and also perhaps for noise cancellation when on a “normal” call.
What is it like when on a “normal” call which primarily uses the microphone near the charge port, you didn’t say?
Here’s a link to the service manual that may help.
Score 1
2 Comments:
If by "normal" you mean using the earpiece it works perfectly fine. No echos or any other abnormalities. And yeah I've completely stripped the phone 2 or 3 times out of boredom just to see if there would be any changes and to insure all connections are solid. No luck
by
Did you ever find out the problem? I'm having the same problem...
by
Add a comment
Add your answer
Ethan Leroux will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 10
All Time: 681
