Repair guides and support for computer monitors produced by Samsung.
88 Questions View all
Samsung C32HG70 horizontal lines
I brought a Samsung C32HG70 a few days ago ( no power and when it was had the vertical lines until warmed up issue). I’ve manager to sort the power problem and also the vertical lines, however the panel has horizontal lines across the whole screen anybody have any ideas on what it might be? Included couple of pics running the Xbox Series X on it today.
Update (02/08/2021)
I’ve had the back off the panel again and it seems to have a small 3mm split in one of the lvds that connects it on the lcd panel at the bottom, could this be causing the issue?
like circled in the picture here.
Score 1
Add a comment
Most Helpful Answer
had the same problem, remove 2 smd resitor and mine was fixed.
if u have the one with 4 resistor and the rt6820a just remove the 2 ones that are vertical farther away from the controller.
Update (04/29/23)
like so
Score 1
2 Comments:
What function does rt6820a perform? I can't find the datasheet. In the LCD monitor, the chip heats up to 150 degrees and turns off. I can't find the reason.
by
Removing the resistors you showed was not a solution for me, but I discovered something new. The process I have done is available in the forum here. I had to use your photo, I didn't have a clearer photo, sorry.
Link: https://www.technopat.net/sosyal/konu/ms...
by
Add a comment
@coys77 yes. Those are the ribbon cables coming of your driver boards. Any damage to those will manifest itself by errors on your display.
Those ribbon cables are connected via a special process (TAB) which makes it almost impossible for a DIY repair. You are most likely in need of a new panel.
Old question and this is just to clarify things.
Score 1
Add a comment
Horizontal or a vertical lines on your LCD display usually indicates a bad LCD display (the panel itself has a very "partial", or "localized" failure). You can try with another screen to see if the issue insists. Or check out the post - How to Fix Vertical Lines on Monitor.
If it is the hardware problem, you’ll have to replace the screen.
3 Comments:
Thanks for the reply, added a quick update to the question.
by
@coys77 You're most welcome.
by
by
Add a comment
I had the same problem, I removed 2 smd resistors and mine didn't resolve, there are still horizontal stripes at the bottom of the screen, of course until it warms up, then it's ok, maybe some idea
1 Comment:
@jozsefszenasi what exact model is your TV? Which Resistors did you remove? Post some pictures with your question so we can see what your TV shows you. Adding images to an existing question
by
Add a comment
Add your answer
Karl C will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 69
All Time: 1,409
