Doors interchangeable from 2002 to 2004
Will the doors from a 2002 Dodge Dakota fit a 2004 Dodge Dakota
That generation Dakota was made from 1997-2004. The type of door will depend on the cab style. Regular, Club, and Extended cab doors are interchangeable, however the Quad Cab doors are slightly shorter. Side note, Dakota Quad Cab doors are interchangeable with that generation Durango doors. So just make sure the cab you are salvaging the door from is the compatible size and you should be good!
May need to transfer the wiring harness, but that's probably not an issue.
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 54
All Time: 3,185
