Repair your Dyson V7 Motorhead vacuum with a part replacement guide.
1 Questions View all
Dyson v7 Motorhead flashing red lights and not charging.
Hello, my Dyson v7 motorhead isn’t charging. After pressing the button to use it, the vacuum would flash a red light at the bottom for a short while before shutting off. The same happens upon plugging it in. Does anyone know what is going on, if so how do you fix it?
Score 2
Add a comment
Most Helpful Answer
first check if its over 12 blinks or less if more its the battery if less its the motor so if its more you need to replace the battery if less search it up
Score 1
Add a comment
Sounds like you probably need a new battery. If it flashes red 10 or fewer times, the Dyson website says you need to contact them. But if it flashes red 12 or more times, then it's just a dead battery. Order a battery here on iFixit. I'm waiting for mine to arrive tomorrow.
Add a comment
Add your answer
Michelle Mills will be eternally grateful.
Past 24 Hours: 11
Past 7 Days: 80
Past 30 Days: 398
All Time: 5,338
