The Mi 10 is a mid-range smartphone by Xiaomi released February 2020. It has a 6.67" AMOLED display, a 108 MP main camera, an in-display fingerprint sensor, a 4780 mAh battery, and runs on a Qualcomm Snapdragon 865.
Power button is stuck
How easy wwould it be to replace the power button on this device?
Score 3
Add a comment
1 Answer
I know is an old question and most probably Jismy is no longer needed it.
The answer is: The process is a little complicated similar with changing battery process, but you have to take out also the main board, because the power and volume rocker buttons are on the same ribbon cable which is connected beneath the main board.
I replaced one year ago that ribbon cable.
As a starting point for the process you can use the battery replacement guide: Xiaomi Mi 10 Battery Replacement
Add a comment
Add your answer
Jismy :D will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 29
All Time: 1,048
