Repair information and guides for the CDMA version of the fourth generation iPhone. Model: A1349 / 8, 16, or 32 GB storage capacity
295 Questions View all
Is the ear piece filter necessary?
So this week I replaced my Iphone 4 screen with a new one after cracking my old screen. After looking at the new screen I realized that the ear piece looked different. When I compared it with another phone I saw that, what I am calling the filter, was missing.
It is the metal, mesh screen behind the ear speaker opening. ANyway, is this piece necessary? Everything seems to be working fine it is just sort of an open hole into the phone which scares me. Further if this is a potential problem can I replace this?
THanks for the help, this site saved me some cash big time!
Score 1
Add a comment
Most Helpful Answer
I found a cheap workaround to avoid taking the phone apart and posted my solution here.
Score 2
Add a comment
I wouldnt guarantee it but I dont think its vital to the functionality to the phone. I'd say at best it filters any dust and debris that might go through that hole into some sensitive hardware inside the iphone. It might be worth replacing because down the road you might wonder why you cant hear anything when people call.
Score 1
Add a comment
The problems won't be immediate, but the dust going inside the phone is bad. Lint can hold moisture and bridge connections...causing your phone to not work well, or at all.
Why don't you cut the mesh down and try to slide it into place? It will still look off, but you will have some protection- that is unless you would prefer doing it the right way and disassembling the phone (look at it as an investment).
Score 1
Add a comment
I found that leaving it off resulted in sounds being really buzzy when talking to someone. It's best to leave it on for dust protection as well as having a good sound.
Score 1
Add a comment
As above really, it is advised to put it in there purely to protect the insides of the phone from dust/lint. It is easy to fit after you get the screen off just time consuming to get it all apart.
Add a comment
Whoops forgot to install the little earscreen?......myself i wouldn't worry about it, just look at your home pc and how much garbage gets in there. Only prob i can see is if the little fuzzys get in there after about 3 years of buildup and u decide to use your phone in a wet sauna.
Add a comment
Add your answer
redacted will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 12
All Time: 14,282
