Repair information and guides for the iPhone 6 Plus that was released on September 19, 2014. Model: A1522, A1524
1527 Questions View all
Pentalobe screws are stripped
I was given an iPhone to replace the battery but she had someone try to do it before and the person ended up completely stripping the screws, I’ve tried everything from the rubber band to hot glue and I can’t get the screws out. What should I do about it?
Score 1
Add a comment
1 Answer
You could tap the head of a torx 6 driver in super glue and try to stick it to the screws. You could use a very sharp flat head and try to get the head into the screws. You could take a torx 2 and try to use the stripped head. Lastly you could drill the screws out. If you do find a way to get those tiny screws out please comment what worked!
Add a comment
Add your answer
Dedrayzion Jones will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 49
