Early 2011 Model: A1278 / 2.3 GHz i5 or 2.7 GHz i7 processor
USB Ports / Accessories Disabled
Hi,
I am repairing a friends Macbook Pro Early 2011. The HDD had failed and they were desperate to retrieve photos.
I managed to do a deep scan on the HDD and recovered the photos to my NAS and I have just fitted a new Toshiba 500GB HDD.
I tried to install Mac OS High Sierra using a bootable USB device however the device was not recognised so I had to install Mac OS Lion using Internet Recovery.
Once I go Lion is running I have identified that neither of the two USB ports are recognising any of the three USB Thumb Drives I have.
I upgraded the OS to Sierra by downloading the OS from Apple and thought maybe that would do the trick but still no USB ports working.
I have reset the SMC (I believe this model has to use the non removable method) the power light is supposed to blink when doing this with the Shift / Alt / CMD and Power button held down but it did not? When I released the buttons the power light went green and then orange?
I have also tried reseting NVRAM by using the CMD Alt P / R and power on chime twice and then let it boot up. Still no USB ports?
I have just also tested a powered USB hub and the Thumb Drives connected still do not show up. This hub works on my own (newer) Macbook Pro.?
Anything else I can try?
Update (04/03/2021)
Still have the overcurrent warning and no USB ports working?
2 Comments:
None of the USB devices I am using are USB3.0 they are all old.
Anyway, with nothing plugged in, I followed the guide on this page to boot into single user mode and after it finally got to the command prompt it started displaying the following overcurrent message:
AppleUSBHostPort::InterruptOccurred: overcurrent detected with port status 0x4000, localSimulatedInterrupts = 0x0
So that tells me there is a problem associated with the USB ports?
I cleaned them with rubbing alcohol and after booting up I was met with the following message on the screen:
USB Accessories disabled - Unplug the accessory using too much power to reenable USB devices.
by
Yes, you have a USB power issue either the contacts in one of the ports is damaged or the logic boards power circuit needs repairs.
by
Add a comment
1 Answer
Remember the USB ports on this system are the older USB 2.1 (480 MBit/s) which uses the larger 4 contacts (two power two data). The USB drives you are using may be the newer USB 3.0 (5 Gbps) which uses the additional six contacts on the other side in the USB 3.0 ports.
The power services in this series was not very high so high draw devices might not work and you will get an alert if the current draw exceeds what it can offer.
If this is happening with nothing connected, I would check the contacts for damage and your power logic on the logic board may need repairs.
2 Comments:
Anywhere I can get the board repaired cheap in the UK?
by
Add a comment
Add your answer
JonnyAlpha will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 30
All Time: 599
