The home base for Android tablets.
Replacement Touch Screen For Generic Android Tablet?
I have a generic 10.1” Android tablet with a cracked touch screen, (the LCD itself is fine.) I’m looking to order a replacement touch screen for it but the problem is it’s a generic tablet. I have looked all over the device for some kind of model number or anything, and there are no such markings. I can’t check the info in the tablet’s settings because of the cracked touch screen. Could someone please point me to a replacement 10.1” replacement touch screen that would work with a generic tablet?
Add a comment
1 Answer
Chosen Solution
Hi @startropic1 ,
Getting a replacement touchscreen may not be easy as you would have to know what the original was first or at least the make and model number of the tablet. This is because they aren’t all the same, even though they may have the same dimensions. The wiring may be different and even if the same number of wires were used between the screen and the systemboard they may not use the same numbered wire for the same function.
If there are no markings on the outside of the tablet then you may have to open the tablet and check for some on the inside. Check for any info on the touchscreen’s flex cable and if there is any then search for it.
Alternatively you may be lucky and that the tablet supports OTG (on the go).
If it does you can connect a USB mouse via a suitable OTG adapter (example only) and use it to navigate through the tablet to hopefully find out the model number information etc. Usually this is found in Settings > About.
If you have an old USB cable and mouse you can make one yourself. Here’s an image to show how it is wired.
(click on image to enlarge for better viewing)
If the tablet has a pin number you can try first with a USB keyboard to enter the pin number and then change to a mouse but it doesn’t work all the time with keyboards. Also if you have a pattern lock this won’t work at all.
Be aware that the mouse will operate on the tablet’s battery so it will discharge a lot quicker than normal when using it so maybe have a fully charged battery before you start ;-)
Score 2
3 Comments:
I popped the back off the tablet, and the serial number on the touch screen ribbon is: rp-328a-10.1-fpc-a3
Also "GA10_V1.1" is printed all over the place on several boards/components inside. Maybe that's the model of this tablet?
by
@startropic1
Searching for "rp-328a-10.1-fpc-a3" brings up lots of results for 10.1" digitizer (touchscreen) suppliers, so given the cost (example only) it's definitely worth getting one and giving it a try
Having the same part ID number is usually a good indication that it will have the same wiring configuration.
Searching for GA10 brings up two tablets, an Ippo GA10 (Alwinner A23)and a Gpad GA10 (Alwinner A10) as brand/model names so there may be some differences in the software perhaps and possibly some minor differences in the hardware features perhaps but usually not the digitizer
Once you get the replacement digitizer installed and working the model name should be in the Settings area of the tablet.
by
I got a replacement touch screen, but I kind of damaged the LCD in the process of removing the old screen. (No big loss, it was a measly $60 tablet. This project was partially for me to practice replacing screens anyway.) I'm off to order better screen removal tools from iFixit and a new cheapo 10.1" tablet.
by
Add a comment
Add your answer
Startropic1 will be eternally grateful.
Past 24 Hours: 8
Past 7 Days: 29
Past 30 Days: 93
All Time: 1,655
