Released in July 2018, the 15" MacBook Pro, model A1990, features a 15.4 inch LED-Backlight display with True Tone technology, TouchID, and up to 6 Core i9 Processor.
How to open bottom plate?
Does anyone know how on earth i can get the rear clips on the backplate of a 2018 15" MacBook Pro to release? I was following this guide (MacBook Pro 15" Touch Bar 2018 Lower Case Replacement) and I could do everything until it said to "Pull firmly to slide the lower case towards the front of the MacBook", I've tried doing so repeatedly and the clips just wont release. I don't want to pull any harder as I'm afraid of damaging something inside.
1 Comment:
Make sure that you run the plastic pick around the front and the side of the laptop to release all the hinges on the side and then try to slide it forward. I think something is still catching on yours on either side.
by
Add a comment
1 Answer
Here’s the key!
So you need to lift the bottom edge using a set of plastic picks and a suction cup to lift the cover over the edge sliding the bottom cover down to clear the tabs and the snap catch.
Add a comment
Add your answer
BlueCreeper512 will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 21
All Time: 431
