Repair information for the Samsung Chromebook Plus. Released in February of 2017. Model number: XE513C24.
23 Questions View all
How do you replace the hinge on Samsung Chromebook Plus V2?
It’s fairly easy to remove the display assembly, and then removing the trim piece across the bottom of the display reveals the hinges, but the hinge screws are obscured by the glass. Is it possible to remove and replace them?
Score 1
Add a comment
1 Answer
You're pretty much better off replacing the whole display assembly now, since the grade A OEM parts are not that expensive anymore. Also, it would be hard to find the hinge itself as a replacement.
Add a comment
Add your answer
Mike will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 82
