The Samsung B1445A is a front-loading high efficiency washing machine by Samsung.
17 Questions View all
Samsung front load power shut down and door locked
My Samsung front load washer power shut down and the door is locked. I tried the outlet and no response. I can’t even get the model number since the door is locked . I don’t know if this will help but the Samsung washer is a super speed power foam stem VRTplus . I never had issues with it and it suddenly stop while the machine was running.
1 Comment
What is a Signal button? I am assuming a Signal button is either the Power or Start that I tried separately with the Soil, but no response.
by
Add a comment
Most Helpful Answer
Hi,
Have you tried looking on the back of the machine for the model number?
Also try pressing the Soil Level + Signal buttons (both together) for 3 seconds and check if this allows you to open the door.
Update (04/27/2021)
Hi,
Without a model number it is difficult.
This is the user manual for a Samsung VRT that says to press to Soil + Signal buttons for 3 seconds.
But since your model hasn’t got one then try operating the Spin and Soil buttons for 6 seconds as described in this user manual which is also for a Samsung VRT but obviously a different model although its Control panel also shows a signal button as well.
Did you check on the back of the machine for a model number, you didn’t say?
Score 1
Add a comment
Wow! I did it. Without finding the model number. How? I started the machine again. Midway, I stopped the cycle. Then I held the start/pause button for at least 10 seconds because this made the water begin to drain. Then I released my pressure on it. It didn’t open. Then I pressed the start/pause button again for 3 seconds and click, it unlocked and opened! Either I’m a genius or I got lucky but there you go! I’m excited to provide an answer here.
Add a comment
Add your answer
Bella will be eternally grateful.
Past 24 Hours: 10
Past 7 Days: 29
Past 30 Days: 202
All Time: 2,530
