A more affordable, purely handheld version of the Nintendo Switch game console, with integrated Joy-Con controllers and a slightly smaller screen. Released September 20, 2019.
184 Questions View all
L, ZL, -, power, and volume not working after joystick replacement?
Okay, I used the awesome tutorial and replaced the left joystick on the switch, it works great but now I can’t get the above listed things to work. I’ve taken it all apart and put it back twice and once the power button worked but not the volume. Any ideas?
Score 1
Add a comment
Most Helpful Answer
In my case I hadn't clicked down the daughter board connector cable to the main board. (Bottom of switch.. over battery connector) once I had taken off the cover and shield simply reseating that cable worked.
If more than one thing on the daughter board is not working then it'd highly like that the cable is not seated correctly or is broken
Score 1
Add a comment
My best guess is that you have maybe missed the yellow ribbon cable that runs between the daughterboard and the main board.
Otherwise, there is damage to the connectors or cable itself. The fact that the whole of that side in not functioning is good (relatively speaking…).
May I ask how you know the volume, and ZL and L buttons are working if power doesn’t?
Good luck in any case
Add a comment
Did you fix the problem yet?
I have the same issue after replacing the joystick, new ribbon cable didn´t change anything!
Minus button
ZL
Cross to the right
Power
And Volume Buttons
Dont work at all
I can turn the Switch on by plugging it into the charging cable
2 Comments:
by "cross to the right", do you mean the plus button?
by
I mean the DPAD sorry my fault. Up, Down and Left work but not right.
by
Add a comment
Add your answer
Tessa Lyon will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 24
All Time: 553
