Second generation Learning Thermostat from Nest Laboratories
20 Questions View all
Why is the new battery not powering the device?
I received my new battery for my nest 2nd gen thermostat from I fix it. After I installed it, I charged it with a USB charger. After several hours of charging, the Nest device won’t turn on. When I plug it into the wall, I get a red blinking light at the top. I know I’m installing the battery correctly because, I was able to install the old one and get it to work. Is there a problem with the device or the battery? Thanks!
Add a comment
1 Answer
your best bet would be to contact customer support about getting a replacement battery. sounds faulty. ifixit is usually good about solving this for you.
good luck
Add a comment
Add your answer
Brad Burns will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 81
