Repair guides and support for Kenmore washing machines.
1894 Questions View all
Why won't my kenmore washing machine powering on
Kenmore washing machine (model 40272900) won’t power on unless I unplug and plug back in. Single circuit to the washer with GIFI outlet remains powered. Once powered up it runs through a whole cycle but once it is done I can’t run another load without unplugging and plugging back in.
Add a comment
Some machines must be level and the load in the machine must be balanced. When you unplug and plug back up you are resetting the safety controls on the machine. As your saying it does this every time I would make sure the machine is level.
Add a comment
Is there any indication there is power to the machine? If so, is there any error codes? If not, it sounds like you have a failing controller. It would be a lot cheaper just doing your unplug routine.
3 Comments:
I have a similar issue with my machine. I am sure there is power at the wall. However, I get nothing after unplug/plug.
by
Kenmore 40272900
by
This morning, my wife tried the power button and it works now. This machine has done this a few times now.
by
Add a comment
Add your answer
Reginald Jones will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 139
