Hi, I am unable to power on
Unable to power on my laptop,even after battery removal
Score 2
2 Comments:
What happened before it wasn't turning on? did it power off suddenly or after the battery drained?
by
i had the same problem - i could not power on, and had difficulty powering off completely. the power button was flashing slowly along with the caps lock key - the screen was pulsating gently at the same rate. when the mains power was plugged in it would power down completely if i held the power button down, but would not power up.
any way - i loosened all the screws and took off the bottom to see what i could see - and that fixed it!! so i gave it a small clean and pressed one or two things in place in case it was a poor connection - it is now running again.
by
Add a comment
1 Answer
Hey Wow,
Are there any indicators when you plug in in to AC power?
Do any lights show up?
Add a comment
Add your answer
WoWsOmE ViN will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 15
All Time: 350
