The Wi-Fi only version of Apple's iPad 6, released in March 2018. Available with 32 and 128 GB storage options. Features a 9.7" Retina display and 64-bit A10 fusion chip.
151 Questions View all
Need help identifying a resistor value (iPad 6 LTE/WIFI)
If anyone has an iPad 6 (with cellular!, there was no cellular select option in the ifixit dropdown) and is able to measure a tiny resistor near the 610A3B tristar chip, as pictured, that would be great. It came off the board during a tristar replacement and no schematics are available. iPad air 2 schematics suggest it may also be 10K but I’m not 100% sure.
This would help immensely!
Score 1
Add a comment
Most Helpful Answer
@kylegp great job on getting it fixed. As usual I am late to the party. This is actually more for my own learning experience with this iPad. I checked a few things and got really confused about the reference designators you guys were talking about. Looks to me like your missing component is actually R8399 which would make it a 0 ohm resistor. In that case and if I am looking at this right, you could have just used a jumper on it.
Score 1
Add a comment
hi kylegbp,
I think this is a line named 12a3b_usb_brick_ID_R connected to R4001 6.34k 1/32W 01005 and goes to c4001 0.01UF 6.3V X5R 01005 on line 12a3b_to_PMU_usb_brick_ID (PMU position r13)
for checking me, find out c4001 parameters and confirm that here - next left capacitor on your picture
8 Comments:
I think c4001 is 10nf (0.01UF). iThanks tojaert, where did you get this information?
by
I look at the picture you posted - so small, 01005 and 10UF? Are we talking about the same capacitor? Check again line continuity.
by
@tojaert Please check again, I didn't say 10UF. I wrote 10nF.
I believe it's the same as what you posted, just wondering where you got the information from?
0.01UF = 10nF.
by
:-) yes, absolutely right (looked different, my mistake. Too fast today, sorry). I took this value from my experience and knowledge of microelectronics.
by
@tojaert All good! We all have those days. I'm having one with this %#*@ resistor haha. I have some 5k resistors and some 10k resistors but not 6.34k. Is it possible to use a higher value in this case or should I use 6.34k only?
by
Show 3 more comments
Add a comment
Add your answer
kylegp will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 30
All Time: 254
