The Amazon Fire HD 8 (5th Generation) is a sleek, black tablet released by Amazon in September 2015. Model Number: SG98EG.
39 Questions View all
Why does my touch screen not work after replacing the Screen?
I have replaced the screen with two new screens and both screen work perfectly except for the touch screen element doesn’t work - is there a connection i am missing or a software reset option that can resolve this?
2 Comments
further to this - i have checked everything inside the unit and it all seems fine so can't see why only the touch screen isn't working. which connection on the device is related to to the touch screen so i can ensure it is seated correctly.
by
just wanted to add a comment in a hope that this would bring it up the response table - i'm still having this issue and the tablet is now siting redundant until i can rectify this issue
by
Add a comment
1 Answer
Chosen Solution
Did you get your replacement screen from iFixit or somewhere else? If you are fine using the tablet without using the touchscreen do the following:
  1. Get a wired mouse and a Micro USB OTG adapter
  2. Charge the device
  3. Plug the OTG adapter into the Micro USB port.
  4. Plug the mouse into the female USB port on the OTG adapter.
  5. You should see a pointer on the screen.
Score 1
Add a comment
Add your answer
Peter Gustafson will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 36
All Time: 582
