Full capacity smartphone released on AT&T, with 4G LTE connectivity.
10 Questions View all
The phone won’t charge
i attached the image of what exactly i think is causing the phone not to charge, but im not 100% sure if that’s the problem. had this phone for YEARS so im sure there might be other things wrong. what can i do to fix this?!
Add a comment
1 Answer
That definitely shouldn’t be bent like that, I suppose you can Try very carefully bending it back in place with a very small tool as a solution and see if that works, other than that, completely replacing that connector entirely may be possible, though it is directly connected to the mainboard.
Add a comment
Add your answer
Julie will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 46
