The HP LaserJet CM1415fnw is a multifunction color printer produced by Hewlett Packard.
19 Questions View all
Having several paper jams
Every thing seems to be working fine with the printer from a communication point; however, every 2nd or 3rd piece of paper jams as it is coming out. I have check to ensure no paper is clogging port where paper is being dispensed and cannot understands why it wrinkles.
Please advise,
Paul
Score 1
Add a comment
1 Answer
Most Helpful Answer
you may need to dig a bit deeper. there is a roller that rolls the paper through on most printers. Some times there is 2-3 of them. And it could be at any of those that is the problem. I believe on your printer you can pull the back cover off to get a better look at all the rollers. you may have a small piece of torn paper that only comes around and causes issues every so often.
Score 1
Add a comment
Add your answer
Paul Staples will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 19
All Time: 251
