The dv5-1125nr is an multimedia entertainment laptop that features a 15.4" display, a built in camera, and toggle touchpad
10 Questions View all
DV5 1215ee is not turning on while plugged in
Why my pc is not turning on when I plugged, only glows charger light near charger port and I try battery reset method (remove the battery and unplug the charger and press power button for 15 seconds) this didnt work. What is do??
System
HP Pavilion DV5 1215ee
Add a comment
1 Answer
Most Helpful Answer
Hi,
Does it turn on when using the battery only i.e. charger not plugged in?
Try a full power refresh and check if that resolves the problem.
Here’s the procedure:
i). Disconnect the charger from the laptop, if connected.
ii). Remove the main battery from the laptop.
iii). Dis-assemble the laptop to a point where you can remove the RTC (Real Time Clock) coin cell battery from the motherboard. Note: Remember the orientation of the battery before you remove it. Usually it is +ve on top as marked on the battery.
Here’s a link to the relevant section of the maintenance and service guide for a DV5 1000 series laptop that may help (I couldn’t find one for your exact model but this should be similar).
When the RTC battery is removed from the laptop, measure its voltage. If it is <2.5V DC replace it. Usually the battery is a CR2032 type battery (marked on battery itself) and is commonly available everywhere e.g. supermarkets. These batteries are a non rechargeable Lithium battery and have a life span of approx 5 years
iv). Press and hold the laptop Power button for a full 30 seconds and then release it.
v). Reinsert the RTC battery (remember the orientation).
vi). Re-assemble the laptop and reinsert the main battery and connect the charger and try turning on the laptop.
If it starts, once fully booted, check the charge status of the main battery. If charging allow it to fully charge and then create a Win 10 battery report to check its status. Compare the Design Capacity value against the Full Charge Capacity value to know the percentage status of the battery i.e. what percentage is the FCC value of the DC value. This is just so you know how good the main battery still is.
Score 2
3 Comments:
I tried the power reset method ,But It doesnt work.
It doesnt turn on on battery becuz battery is faulty ,early time it turn on with plugged in.
I checked the RTC battery , the voltage is showing 2.92V, so the battery is not faulty.
by
@Mosaic Wolf Tech
What is the make and model number of the motherboard (printed on the motherboard itself)?
The laptop shows that there is power but this doesn't mean that the correct power is being received on all the necessary power rails.
The schematics will have to be found so that you can use them to trace the circuits and check if the power rails in Standby mode i.e. laptop is off but power is connected are OK and that the Power button when pressed is working to signal the BIOS to turn on the laptop.
by
Yeah now its worked Bro. Its power button Failure. I Tried with shorting the power button connector with a wire. Now its fine. And sorry for late reply
by
Add a comment
Add your answer
Mosaic Wolf Tech will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 329
