Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
Magsafe Board changed...No power!
I'have changed the Magsafe board. Magsafe LED is green,
But no power
Reset SMC
connector keyboard ok
It's a MacBook 2009 white. I think that the keyboard does not function, and i dont find power connector on the logic board.
thank you for your help
Score -1
2 Comments
Please give us the last 3 characters of your serial number so we can verify your exact machine.
by
It' a early 2009 the Keyboard was changed and the serial is on the Keyboard
by
Add a comment
1 Answer
Most Helpful Answer
Check the voltages at the battery connector using a multimeter or similar. The two outer pins are ground. The three inner ones should read something around 3,5 V. If the machine suffered a spillage have a hard look at the Magsafe -> board connector and also at the Board -> battery connector.
Score 3
1 Comment:
The 16.5 VDC, pinout is on the right side of this link: http://en.wikipedia.org/wiki/MagSafe
by
Add a comment
Add your answer
Mikhrych will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 452
