ASUS Chromebook C523NA is a Chromebook laptop manufactured by ASUS that was released on October 23, 2018 and is compatible with the Google Play Store2. It is the first ASUS Chromebook to feature a NanoEdge design, for a larger screen but more compact design.
13 Questions View all
My C523 Will Not Charge
My C523 Will not charge from either USB-C ports. The charger is good as it works on my wifes chromebook. I opened it up and everything looks to be connected properly. Any ideas?
2 Comments
I have the same model with same issue. Both ports won’t light up and can’t even turn on. Is there a way just to change the charging port?
by
I ended up replacing the motherboard as I didn't trust my abilities in soldering on a board. Found one on ebay for around $150 I think. This was going to be for my kid at school so didn't want to buy new with the inflated prices pre-school year. Fairly easy install with the right tools. Got it all done and then the school came out a week before start and said outside computers not allowed as they had enough to go 1 to 1 for the year. FML...
by
Add a comment
1 Answer
Most Helpful Answer
If you wife’s Chromebook is the same model try swopping batteries.
If her battery charges fine in your laptop and your’s doesn’t charge in her’s then you know that you need a new battery.
Asus Chromebook C523N Battery Replacement
Score 2
5 Comments:
Its not the same battery. Are there other indicators that would help diagnose a non-functional battery? On mine the light wont even turn on when plugging it into the charger. Does that lean to a bad battery or a bad motherboard?
by
Hi @Sean Goodman
Just disconnect the battery and try to run Chromebookl with just the charger plugged in. If all is well then the battery is probably defective and I would guess shorting out the system.
It could be something else but let's just try this to start.
by
I have the same problem, but disconnecting the battery and plugging it in does not allow the computer to run. What's the next step?
by
@Peter Anderson
What is the make and model number of the laptop?
Do you get any indications on the laptop when a charger is connected?
If not maybe check if the DC-In jack is OK.
by
try disconnecting the battery then plug it back in while the usb c cable is pluged into the chromebook that worked for me
by
Add a comment
Add your answer
Sean Goodman will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,489
