Released in 2015, intended as a workstation for CAD CG professionals, or as small-scale business servers.
3 Questions View all
I need to find bios admin password (dell precision m3800)
Hello,
I have Dell Precision M3800 Laptop and I need Admin BIOS password for this laptop.
That password blocks almost everything in BIOS. I tried few times un-plugging CMOS Battery and holding or pressing power button, command prompt lines, but completely nothing works.
Service tag is: CD0YX52
Express Service Code is 26909077574
If you can help me with that i will be very grateful,
Thank You
Mariusz
Add a comment
1 Answer
Chosen Solution
Hey Mariusz,
I would think removing the CMOS battery for a period of time would do the trick. I know you stated you have done this, but have you left it completely unplugged for 30 minutes with the battery out? The capacitors on the board can still hold a charge for a while, storing the password for as long as they have a charge. Once they are drained it should remove that password.
In some cases Dell has a ‘backdoor’ password that is just the word Dell (with a capital D)
Hope this helps!
Score 1
1 Comment:
Hi,
I know that :) I unplugged RTC jack from socket for 30 min also with main battery unplugged, only BIOS Date was restarted, nothing else happened - as far as I checked on Dell website - Admin password is in some NVRAM chip (non-volatile), so even without power it keeps password after unplugging bios battery.
However - maybe this RTC jack only restarts Real-time clock itself (that explains date restart), not whole BIOS - It's a small white plug with red and black wire, don't know where is it going :)
Tried that Dell password, didn't worked either.
Anyway thanks for answer :)
Mariusz
by
Add a comment
Add your answer
Mariusz will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 14
Past 30 Days: 23
All Time: 787
