The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering. This page aims to help users troubleshoot, fix, and seek help for the iPhone 2G.
224 Questions View all
Broken Sim Reader Pins
Hello,
I always wanted a first generation iPhone and I bought a first generation IPhone to repair. I realized that my device is not reading SIM cards. Then I opened it and saw the broken pins. Can I just buy a broken motherboard and replace the sim slot? If not how could I fix it?
Add a comment
1 Answer
Chosen Solution
I have replaced sim holders on a lot of iPhones but not this model. It looks easy enough. I am not sure how much heat you will need to melt the solder on these models, if you flow the joints with low melt solder you shouldn’t have a problem although you will probably need a hot air station as well as an iron.
The hardest part will be finding a non-working one to buy.
Score 2
1 Comment:
Thank you so much?
by
Add a comment
Add your answer
Batu Köseoğlu will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 17
All Time: 78
