The Apple Extended Keyboard is a USB-A extended keyboard with an aluminum body and a numeric keypad.
5 Questions View all
Mac keyboard typing wrong letters
hi there!
I’ve got issue with my extended mac keyboard. As an exemple when i’m punching the letter P, the O also appear.
It also doing it with the L and the ;
I noticed that these keys are alongside on the keyboard.
Someone have a solution with this issue?
Add a comment
Chosen Solution
You must have had a spill into the keyboard so the signal lines are damaged shorting out.
Think of it this way… Your keyboard is a grid of horizontal and vertical lines. The point where they cross is the Key shorting them to make the given signal to the keyboard encoder. This is all done within the keyboard.
Sadly, Apple does not design its newer keyboards as serviceable. Time for a new keyboard ;-{
1 Comment:
Thanks a lot for your answer Dan! :-)
by
Add a comment
Most Helpful Answer
Replacement required
Score 1
Add a comment
Add your answer
Jean-François Duguay will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 38
All Time: 2,911
