Introduced in 2016, the Brother MFC-L6700DW monochrome laser All-in-One addresses the business needs of workgroups with higher print volumes. It boosts printing and copying at up to 48ppm. The large 520-sheet capacity paper tray holds more than a ream a paper for fewer refills, and for additional capacity add-on trays boost total capacity to 1,610 sheets.
8 Questions View all
I have a Brother MFC-L2740DW and I need to replace the Network card
To replace the network interface card. I have done the reinstall of everything over and over and over. Luckily I have two of the same printers. So I got the other printer put it in place set the network card up and it worked. Network card needs to be replaced!! Help
1 Comment:
Did you ever get this solved? I have an MFC-L3770CDW that only shows as inactive on the network when wired but it works fine on wifi. I'm a tech though and always prefer to run wired if it's an option. Without extensive troubleshooting, it seems like the lan connection is dead.
by
Add a comment
Sadly you’ll need to contact Brother to locate the needed part
Add a comment
@winchell this is just for completion sake of an old question. The WiFi card according to the parts manual for our printer is a Brother LD1969001 card. The card is readily available at many online places.
Add a comment
Add your answer
Carole Mahoney will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 6
Past 30 Days: 39
All Time: 636
