The Apple Watch Series 1 is a revamp of the original Apple Watch, announced September 7, 2016. Most of the parts are the same as the Series 2
124 Questions View all
Post-battery replacement, battery no longer charging
Replaced a swollen battery with iFixit’s kit. Was (and continue to be) delighted by the experience. After a little over two weeks of good functionality, the watch no longer charges past 3-4%. It registers once docked, and still communicates with the iPhone — but is no longer a practical device.
Any advice?
Score 2
Add a comment
1 Answer
Concidering that the battery was working for a while after the installation, there may be a defect with the battery.
There is also a good chance that the battery is not connected properly. Possibly the data line of the battery which would cause odd issues as you’re describing.
If you still have the old battery, it may still be able to charge a bit. You could use it to confirm that the new battery is at fault if it charges more then 4%. I would try to reconnect the new battery first.
If none of those seems to work, there is a chance of damaged motherboard components, or partial damage to the charging flex cable. These are less likely since the watch was working for at least 2 weeks after installation.
I hope this helps
Add a comment
Add your answer
fjd will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 15
All Time: 252
