The Motorola X Sol Republic Deck is a bluetooth speaker designed by Motorola, released in August 2013.
12 Questions View all
My deck got wet. Is it salvageable?
So, my toddler sprayed my motorola x sol republic deck with the hose. I turned it off immediately and let it dry for about 2 months before turning it on.
Since then, it will connect, but it seems like there’s a short circuit now. If I adjust the volume using the deck’s buttons, it will power down. And the sound cuts out so frequently you can’t listen to anything. Is it salvageable?
Score 1
Add a comment
1 Answer
Most Helpful Answer
@nosh27 this “let it dry for about 2 months “ possibly corroded some of the components on the circuit boards. Use these guides Sol Republic Deck and try to take it apart as much as you can. Clean the boards with a soft brush and some high-grade isopropyl alcohol. Check for burned-out or damaged components. Post some pictures of your boards etc. so we can see what you are looking at. After it is all cleaned of any corrosion, replace the battery as well and see what you get. Adding images to an existing question
Score 1
Add a comment
Add your answer
nosh27 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 89
