The Lincoln model K2513-1 is an electric flux-cored welder designed for basic wire welding projects and repairs. It can output between 30 Amps and 125 Amps at a rate of 50 - 500 inches of wire per minute.
1 Questions View all
I want to buy Lincoln 180 welding machine
I am thinking to buy a mig welder from the Lincoln brand. It could be this Lincoln 180 MIG welder. What is the difference between these two model? I am thinking to buy this model: https://bestmigwelders.org/lincoln/180-m... . What do you think about this Lincoln model.
Add a comment
1 Answer
Most Helpful Answer
Hi @rswebss
Here are the product sheets for both models.
A quick read through indicates that the K2513-1 is a smaller capacity unit than a MIG 180C (model #K2668)
By this I mean that the output current is only 30A -125A as opposed to 20A-180A and the cored wire size is also smaller i.e. 0.6-0.9mm as opposed to 0.9 - 1.1mm. There are other differences as well but I haven’t read it all to find out.
It may depend on what you want to do with it.
Score 1
Add a comment
Add your answer
Mr Roswobs will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 26
All Time: 237
