75 Watt 8" Subwoofer. Part of Boston Acoustics Micro90t 5.1 home theater package.
6 Questions View all
Woofer on one tower speaker rattles with deep, loud bass
The 10 inch woofer on one tower speaker (Boston Acoustic T930) rattles with deep, loud bass. I replaced the foam on this woofer and did not do a perfect job leaving a slight ripple in the foam. Could this be the problem, or is the cone or speaker likely damaged? Other than on deep, loud bass the speaker sounds fine.
1 Comment
I also found several small sections of the foam that were not snugly secured to the speaker, so I added glue there, and all seems ok so far.
by
Add a comment
1 Answer
Chosen Solution
something could be rattleing from within it make sure all the screws are very tight because the bass will loosen then other long periods of time
Add a comment
Add your answer
John Faulstich will be eternally grateful.
Past 24 Hours: 3
Past 7 Days: 5
Past 30 Days: 6
All Time: 188
