The HP Officejet 6500 is a color All-In-One printer. Released in 2003. Model number: CB815A#B1H.
51 Questions View all
small spring found at rear of printer after clearing a paper jam .
where did a small stainless steel spring 40mm long come from that I found at the rear of the printer base when I opened up the back to clear a paper jam.
It has an eyelet on one end and sort of a hook on the other.
could it be a spring for the tension to the top door that gives access to the glass scanner pane ?
Add a comment
1 Answer
looks like to me you could be right or it is used for one end holding on to the printer and the other eyed end is put onto a gear somewhere a photo of the spring?
Add a comment
Add your answer
mark will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 77
