{A1706 / EMC 3071}—Released in June 2017, this 13" Macbook Pro features Kaby Lake processors up to 3.5 GHz Core i7 with Turbo Boost up to 4.0 GHz.
How to replace the internal Microphone?
I recently bought a MBP used in which the keyboard was replaced under the replacement programme, Post that the person said the Microphone is not working. Would you guide me to open and check where the microphone is connected so i can check it on my own.
Add a comment
1 Answer
Chosen Solution
The microphone connector is on the far right side of the logic board.
This would have been replaced as part of the top case if the device was repaired by Apple under the keyboard program. So if it’s been since that and was relatively recently (within 90 days) I would take it back to them. But otherwise, replacement mic isn’t too difficult once you get the logic board out, the flex cable is just stuck to the top case.
Score 2
Add a comment
Add your answer
Akram Khan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 28
All Time: 822
