Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
Taptic Engine Motor weak vibration
Hi!
I have Changed Back Housing on an iPhone SE2020 which previously was bent. After that I have fitted back everything and I have tested vibrator motor but it is very weak. It makes very tiny sound or vibration but it is not normal.
I have tried an 2 good iPhone 8 Taptic Engine but it is the same problem.
Every other function of the phone works perfect except this.
The board has no damaged components on it.
Any suggestion how to diagnose or move forward? Thanks
Add a comment
Most Helpful Answer
I have never encountered this problem being a logic board issue. It will be a parts issue. Install the logic board into a known good housing and test.
Score 1
3 Comments:
I've done it already.... Drives mad
by
Problem still exist
by
Strange to me, I did as well never encountered this problem before....
by
Add a comment
Do you have access to a microscope? It is possible that the board could have sustained damage that is not visible to the naked eye. I would also try cleaning any connections it uses.
2 Comments:
YES! I have checked under Microscope. Also checked the ARC IC chip and checked did readings no short found.
For now I have ordered another new Taptic Engine to check.
by
Also checked with NEW dock flex which did not resolved the problem.
by
Add a comment
Hi, i have similar problem, but my Taptic Engine go laud non-standard, i even order new housing and the solution for me was changing the dock connector. If you have access to new one? You need to instal to the phone to proper test it.
1 Comment:
I have a spare dock flex. I have tested as well but problem still not resolved. today I have ordered a brand new dock flex I will check if that make any difference.
by
Add a comment
Add your answer
Peter Hupuczi will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 469
