The Google Pixel 2 is Google's second flagship phone, released on October 17, 2017. The phone features a 5-inch AMOLED display and comes with 64 or 128 GB storage options. It is available in three colors: Just Black, Clearly White, and Kinda Blue.
70 Questions View all
SIM tray broke in half, only half comes out. SIM and other half stuck
I've tried getting it with things like sewing needles but it seems if anything I've only further lodged it into place.
Photos:
https://imgur.com/a/bNEtEV8
I will take this thing apart if need be, however I'm not sure which, if any, of the ifixit Pixel 2 guides are what I'd need to be able to access it, or without taking way more apart than necessary.
Add a comment
Most Helpful Answer
Hi @printedwaffles ,
I would use the Google Pixel 2 Motherboard Replacement guide to gain access to the SIM card reader where hopefully you may be able to gently push the broken tray and SIM card back out from the reader, without causing too much damage to the reader pins. Perhaps by using a Spudger you might be able to do this
Getting the reader’s metal case cover off may be difficult if you want to try and remove it to lift the broken pieces out.
If you decide to try this, don’t skip the part about disconnecting the battery from the board. You don’t have to remove the battery, just disconnect it. There is always power on the board even though the phone may be switched off and you don’t want to cause any more problems than what you already have. The power button is not a power isolating button.
Spudger Image
Product
Spudger
$3.99
Score 2
Add a comment
Or get some ifixit tweezers and carefully get the piece out
Tweezers Image
Product
Score 1
Add a comment
Add your answer
Alberto Einsteino will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 36
All Time: 1,196
