Repair documentation and information for the Google Pixel 4a 5G. Released on October 29th, 2020. Model number: G025E
33 Questions View all
Possible to replace just the rear glass cover/lens over the camera?
I have a crack in just the glass cover/lens sitting on top of the camera of the Pixel 4a 5G. is it possible to just replace this part without disassembling the phone or getting a new phone casing?
Add a comment
1 Answer
Most Helpful Answer
CC, it can be independently replaced, but it’s a part of the back cover. In the 4a 5G, in order to access the back cover, you need to remove the screen, as seen in our guide here.
Once you have the rear cover removed, the flash, mic, and sensor need to be removed. You can see that assembly in this step. The lens cover is then adhered to the back cover.
If you source a replacement cover, you may want to find one with pre-applied adhesive, otherwise water resistance will almost certainly be lost.
Score 1
Add a comment
Add your answer
C C will be eternally grateful.
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 29
All Time: 369
