Apple's mainstream 2020 iPhone was released October 23rd and comes with a 6.1" OLED display, a dual 12 MP camera system, and in five available colors. Successor to the iPhone 11.
iPhone 12 wont charge
has anyone got a same problem like me? unfortunately i dropped my phone but it wasnt too hard but after that my phone cant be charged with the normal charger.
Score 1
Add a comment
1 Answer
Most Helpful Answer
If wireless charging still works, then it’s most likely a problem with your charging port. Some repair shops will immediately jump to the conclusion that you need a full replacement, but if you look in your charging port with a flashlight, you may be able to see debris inside. The back of the charging port should be the same color as the frame of your phone, unless it’s been previously replaced, and you only need to be careful near the bottom of the port where the pins are located. Besides that, just use a pair of pointed tweezers and remove as much debris as you can, moving from side to side along the back and top of the port. Then you can use a compressed air can to remove anything you’ve loosened. Just repeat until your phone charges. However, if you look in the charging port and see any pins bent, broken, or corroded, you should go ahead and get the port replaced.
Tools for holding and manipulating small and delicate components. Blunt, pointed, and angled versions. Image
Product
Score 1
Add a comment
Add your answer
Arief Fathan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 12
All Time: 339
