Repair and disassembly information for the first-generation Apple Watch SE, announced September 18th, 2020.
35 Questions View all
Can you name this part..!
I was fixing my I watch had a dead battery and I accidentally ripped the side of this cable shown in the image looks like a ground.. after looking on Google and asking what the cable was or even know what it is? anyone on here help as I need it thanks
Add a comment
Chosen Solution
@steveboy86 that is your display cable. Also referred to as the LCD Touch Screen Flex. Check places like this as well as other possible sellers
Add a comment
System in Package (SIP) module with its ribbon cable unit which connects to the display assembly. Apple doesn’t offer the cables as a serviceable spare to their repair depots. The full SIP will need to be swapped out. If you can find a watch for parts you might be able transfer the cable unit but its not easy!
If you damaged the shielding part you might be OK. I use some conductive copper foil which I insulate on top to connect the two parts together after exposing some of the copper for the foil to connect to 3M RF EMI Copper Foil Shielding
Add a comment
Add your answer
Ste will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 347
