Repair information for damaged wires.
7 Questions View all
office telephone Rj9 cable to mobile headphones
Hey!
I need to use my mobile headphones for an office phone ,
I probably need to buy a converter but it isn't available in my country , so ..
what I did was to cut the 3.5mm jack of my headphones and try to connect it with the rj9 cable..
I was able to get the sound working in my headphones but not the mic
when i try to connect the 2 grounds of the rj9 cable to the ground of the headphones , I hear a terrible whistle
so if any one can tell me the exact circuit between them , it will be great!
thanks in advance!
Add a comment
1 Answer
Chosen Solution
Telephone wiring is not the best wire if you want a clean signal. The microphone side of your head set is so low the SNR can be a problem. This is where coax wire is better suited.
Anyways here’s a good writeup on headphone wiring Can anyone help me identify which wires go to the left, Right,Ground
Score 1
6 Comments:
the problem is there are 2 grounds in the rj9 so if I connect them with the headphones i hear that whistle
by
@Møhámèd Âbđállàh - Why are you connecting both together the current level is not high enough to require it.
by
then how should I get the mic working together with the sound ? the headphones have only one ground .
by
@Møhámèd Âbđállàh - Most headsets have one common ground at the plug end. You have Left +, Right + and Mic + and then the shared ground.
Did you review the URL link I posted to @jayeff great answer?
by
@danj
sorry for late response ..
I have reviewed jayeff's answer ,
I have 4 wires at the end of the headphones
blue : right audio
green : left audio
yellow : ground
red : mic
and at the rj9 cable there are 4 cables ..
assumingly : the first and the last one are for the mic and its ground and the 2 middle wires are for mono audio with its ground ,,,
I tried to make the connection like that :
1. green and blue : mono audio+
2. red : mic+
3. yellow : audio- and mic-
when I connect the mono audio with green and blue and the mono audio ground to the yellow the audio works perfectly ,,
and when I try to connect the mic to red and its ground to the yellow ( so there are two ground connected with the yellow wire) , I hear a terrible whistle within the headphones themselves .. so I don't know what am I doing wrong ..
I hope you can help me ..
by
Show 1 more comment
Add a comment
Add your answer
Møhámèd Âbđállàh will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 23
All Time: 892
