The Motorola Moto Z3 Play was released in June of 2018. It has a 6 inch screen and a non-removable Li-Ion 3000 mAh battery. Its rear camera is 12MP and its front camera is 8MP. Model number XT1929-3, XT1929-4 and XT1929-8. "XT1929-3 NA XT1929-4 NA XT1929-4 NA XT1929-5 LATAM XT1929-6 LATAM XT1929-8 EMEA/APAC"
14 Questions View all
Repair connector on z3 play
Was replacing crack screen and tested by inserting ribbon in connector and it worked. When I took off to apply adhesive I broke piece off on connector and now it will not work. Am I able to replace connector on motherboard?
Add a comment
1 Answer
Most Helpful Answer
@micbob4 that is Motorola connector 09014221001W which is a CONN,ZIF, 61 PIN,0.9MM HIGH, 13.8 LONG. The only online connection I can find is on here You can of course try to match it with something that mouser.com or digikey.com may have. Also, you can always try and purchase a broken circuit board for the same model phone and use that to harvest the connector from.
Score 1
Add a comment
Add your answer
Robert kidd will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 168
