My xbox 360 elite has problem with the Video
My Xbox 360 elite console has Problems with the Video. There are no red lights. I have no picture on the screen only the sound i can hear. My Question is how can i fix it?
You might want to try this. It comes from the MS support site and see if it makes a difference.
1. Remove any discs from the disc tray.
2. Turn the console off.
3. Turn the console on.
Note If you are using an Xbox 360 Wireless Controller, turn the console on by using the Xbox Guide button on the controller.
Note: Make sure that you use the player 1 controller when you do this. The player 1 controller is the controller where the upper-left quadrant light is on.
4. As the console starts, press and hold the Y button, and then pull the right trigger at the same time. This causes the Xbox Dashboard to reset the display settings to the default settings and then automatically restarts the console. So it's OK when the Xbox 360 console restarts. Step 4 is not to clear but you press Y and the right trigger as soon as your 360 powers up (when the centre green light comes on).
Anything else leads to a not so nice possibility that your GPU is not working. You will have to treat that like you would treat the RROD. Hope this helps, good luck.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,074
1 Comment
What have you tried to fix it so far? Changed your cables? Used HDMI or component out? Did you check your monitor to make sure it is in working condition? Checked all your connections?
by oldturkey03
