Dymo LabelManager 160 is fast, compact and lightweight, making it easy to label just about anything, anywhere. Type quickly on the computer-style QWERTY keyboard, edit with one-touch fast-formatting keys and print for perfect, professional labels every time.
Why can't I change the font size over 12
why can’t i change my font size pass 12
Score 1
1 Comment
To enable changing the Font size selection to either 8, 10, 12, 16, 20, or 24, remove and re-insert the Batteries, which enables you change the variable Font settings. Use the Menu button to select one of 3 tape sizes: 1/4, 3/8, or 1/2 inch. The various Font sizes are dependent on the Tape sizes.
by
Add a comment
1 Answer
Chosen Solution
@jeanlouisk52448 @stevenburrows for the labelmanager 160 do a complete reset. That should restore your font options.
Turn the printer off
important - REMOVE THE TAPE from the printer
Now press and hold "Backspace" button the "9" and the "On/Off" button at the same time
You may need to try this a couple of times due to the awkwardness of pushing those buttons or try the ERASE option by
REMOVE THE TAPE from the printer. then press "9" and "Backspace" simultaneously, THEN the Power button.
Score 3
4 Comments:
I did a complete reset including removing the tape. This time the tape options came up on the screen (they didn't on the first install). I chose 12mm and voila, I have the full set of font sizes. Thanks
by
@stevenburrows great. It seems like the reset needs more than one attempt due to its awkwardness :-)
by
Thank you for this explanation. I was losing my mind trying to figure out why I couldn't get a bigger font than 12. All fixed. :)
by
thank you, helpful though its awkward pressing those buttons that far from each other
by
Add a comment
Add your answer
jean-louis kippelen will be eternally grateful.
Past 24 Hours: 7
Past 7 Days: 38
Past 30 Days: 116
All Time: 3,643
